gear box mount
just puttin a new gear box on my 2wd saph and need a new mount. any 1 got an idea were i can get 1?
there on back order from ford. any advice would help thanks |
I recently got mine from ford's, easy to fit, but a bit fiddly, made a world of difference to gearchange though well worth doing.
The mount itself had corrosion welded itself to the gearbox, so had to be knocked free carefully with hammer, and old screwdriver, put some coppaslip on the mating face of new mount to gearbox so it does not stick tabetha |
as above m8 fords ;)
hmmz i'd prefer a graphite based grease. With kopper on aluminium, it can corrode galvanically.
mine came off very easy i have now orded 1 from woodford.
ford there self had them on bak order and could not give a date as to wen they would have 1 thanks any way |
Does the gearbox need to come out? Or can it bee done with the engine and gearbox still in the car? Im thinking of changing engine mounts also.
Bruce |
Gearbox NEEDS to be fitted to do it.
I have a 4" scorpion system and just about enough room with a lever or two, don't lever on the mount too much if it stuck to the box, as it comes off all of a sudden and you get a dent in your head like me, either that or don't be silly like me and lever towards yourself!! tabetha |
Thanks tabetha,
So the engine mounts also can be changed with the engine and box still in place? Just lift the engine up enough to remove old mounts? Bruce |
Originally Posted by broos3
Thanks tabetha,
Thanks jon
Bruce |
I just either put me engine hoist on or use a jack with large flat block of wood to spread the load and support this way.
tabetha |
© 2024 MH Sub I, LLC dba Internet Brands
