Group A coils
#42
My pet is Moonstone blue!
Originally Posted by Cosworth Bassie
Originally Posted by tabetha
still must say the group a is defo loads better than the std ford fit one.
But the MSD coil is better then the group A one.
As said, i did have tried them all, and the car does run smoother and never missed a beat with the MSD one.
#43
Originally Posted by Tommen
There is many types of MSD coils.. what kind is the best for the cosworth?
The MSD blaster coil 2 is a very good coil....And it's plug and play for the Cosworth leads.
#45
the group A coil that everyone seems to be selling is actually available off the shelf from VAUXHALL dealers. sorry for swearing
the part number for coil is exactly the same as a vauxhall nova sport and is priced at £12+vat
dont be fooled by all these companies selling them for £30-£40
get yourself down to a vauxhall dealer if you can bring yourself to open the door, buy the part and have a vauxhall supplied part fitted to your pride n joy
#47
Passion for Fords!
#48
#49
#51
grp a coil
the grp a coil is one of the best mods to compliment a power upgrade,instead of wiring it in to the original loom(11.5v),direct it straight from the battery 13.5v!!!! make sure to put a relay on it and feel the difference!
#53
#55
It may well LOOK the same but resistances are all different as is coil windings, therefore voltage, primarily because it was on a N/A vaux never intended for forced induction which needs a MUCH higher spec to spark under boost.
I have found 7 that LOOK the same and will fit etc, but they are not right.
07-10-2015 12:56 PM
