Timing marks?
I'm changing the head gasket on a 2wd saff and so naturally also doing the timing belt. It does'nt really matter at this piont but I lined up the timing mark on the crank pulley and the only other mark that lined up was the distributor, both cam pulleys and the oil pump mark were off.
When I'm putting the head back on how do I align the cams in relation to TDC no.1 piston? And will the oil pump mark being off affect anything? |
the timing mark on the pulley isn't the V notch - line the trailing edge of the lug immediately after the V notch up with the front oil seal indicator, the cam pulleys should then line up, as should the centre of the rotor arm with the notch in the dizzy body
the auxilliary shaft alignment is irrelevant |
Thats the one I used, the left hand edge of the oil seal indicator is lined up with the left hand edge of the raised lug on the crank pulley.
When its like this the centre of the rotor arm is aligned with the mark on the dizzy but the crank pulleys are off. |
As said aux shaft is irrelevant so long as pulley mark lines up with the notch on the cover lines up with the lug nearest he "V" mark and cams point in to each other, and of course the rotor arm lines up with the dizzy line, the dizzy can be up to 4 degrees off and be ok.
tabetha |
1 Attachment(s)
The image below shows the timing marks as you should have them, how far out are your cam pulleys when the crank pulley is timed up ? Are you sure you are not 360 degrees out on the crank timing ?
Attachment 104837 When I'm putting the head back on how do I align the cams in relation to TDC no.1 piston? Make sure you've got the marks all lined up correctly, before fitting cyl. head or you might bend the valves when replacing head, or you could put all 4 pistons level with each other, fit cyl head, torque down, then time the cams up as per the marks, then turn crankshaft clockwise to the timing mark, set dizzy marks then fit belt..... Hope this helps Cheers David |
aux shaft is not irrelevant. important to get it right to line up the dizzy cap, otherwise it can be very troublesome to remove due to inlet manifold position
If the dizzy has been out it can back in all manner of positions relative tom the timing mark on the aux shaft and still be 100% perfectly timed, with the cap in PRECISELY THE SAME POSITION, this is what people are reffering to.
BTW, they are a pain in the arse on 2wd anyway. tabetha |
dizzy
Originally Posted by dbailey
(Post 2496303)
https://i76.photobucket.com/albums/j...imingMarks.jpg Time crankshaft up, as per the timing mark, time cam pulleys up as per the timing marks, line rotor arm up as per line on dizzy, and there you go ! Make sure you've got the marks all lined up correctly, before fitting cyl. head or you might bend the valves when replacing head, or you could put all 4 pistons level with each other, fit cyl head, torque down, then time the cams up as per the marks, then turn crankshaft clockwise to the timing mark, set dizzy marks then fit belt..... Hope this helps Cheers David thanks chris. |
Originally Posted by chriscossie
(Post 4726588)
hello mate can you tell me what the degrees is on the discap as my car wont run under is own steam put you can rev it put as soon as you let go of the throttle it stops runing put if you turn it two much one way it wont start and if you turn it two much the other way it wont run properly can you help me
thanks chris. so you may have another fault as well |
date!!
and totally incorrect info, timing cannot be altered by cap position, it's set by the cps. tabetha |
© 2024 MH Sub I, LLC dba Internet Brands
