Any EASY way of removing the front struts on a Saph?
As is not dropping the front anti roll bar or bottom ball arm etc?
I'm wanting to fit some springs but after the hassle I had doing the wheel bearings and refitting the frigging hub I don't fancy doing it again and risk busting something else. The escorts and fiestas were a doddle, just remove the bolt and stamp on the hub for a bit and out they came! Cossies have that horrible roll bar and I don't want to ratchet strap the roll bar to slide it in :? |
Just undo the bolt through the back of the hub/shocker and seperate that way?
© 2024 MH Sub I, LLC dba Internet Brands
