Ford Puma Discuss the Ford Puma here!
Puma 1.7 ecu wiring diagram
Old 22-06-2019, 04:17 PM
killa_paul
killa_paul's Avatar
Default Puma 1.7 ecu wiring diagram
It's a 1.6 zetec s , 1.7 puma engine , loom and ECU , car will start when cold , run , once off choke it struggles to idle , when driving its bogged down to fuck till you hit 4krpm then it flies , I've replaced every fucking sensor on the car , all new earths , the lot , only thing I ain't changed I'd fuel regulator and tried a different loom can anyone advise or have an ecu loom diagram
Old 22-06-2019, 05:19 PM
killa_paul
killa_paul's Avatar
It’s a 99 so tape ecu and single lambda ecu
Old 22-06-2019, 07:13 PM
st220kyle
st220kyle's Avatar
Are you sure it's not something like a hose or pipe not connected? Have you got the pipe connected properly from the intake to the evap valve right?
Old 22-06-2019, 07:19 PM
killa_paul
killa_paul's Avatar
Double checked ever pipe and connection
Old 18-02-2020, 09:29 AM
fuji999goat
fuji999goat's Avatar
Default Ford Puma starts, idles badly and stumbles to a stop
Hi, I've got much the same problem - did you ever solve it?
london_chris
Ford Puma
18-07-2019 06:44 PM
-beefy-
12-07-2011 08:13 AM
silky16v
Ford Puma
30-01-2011 07:41 PM
whizzisat114
29-09-2010 04:59 PM
Henrikmk3
04-04-2010 01:29 PM
Quick Reply: Puma 1.7 ecu wiring diagram
