I need help installing my radio
Hello,
Yes, I've searched (and not only on this forum) but I can't find the solution for my specific problem. I've got my first ford puma, however, the place where the radio should be looks like this: http://i42.tinypic.com/dg6h35.jpg I can't figure out what cable does what, I can't find a diagram for the cables and colors of a ford puma anywhere, some users on this forum suggested to buy some ISO Wiring Harness connector, but if you look at the picture, there's no place to conect such cable. And there's no manual for this on my car either I would really appreciate any help because I'm trying to find any answer for this without luck... By the way, I have a Ford Puma 1.7 16V Thanks in advance! Filipe |
Answered on ProjectPuma ;)
quite straight forward really, most fords use same wiring plug, just obtain correct fittings and match the colours up and join together, I'm breaking a fiesta at moment with same wiring but as your in lisbon postage would be expensive
© 2024 MH Sub I, LLC dba Internet Brands
