Ford Puma Discuss the Ford Puma here!
Puma...wont start electrical mayhem
Old May 19, 2011 | 07:14 PM
Mr Sam's Avatar
Mr Sam
Default Puma...wont start electrical mayhem
the Mrs' car had about 4 months and has been okay but randomly wont start
ignition on and the fuel pump relay clicks like crazy i wiggled it and it stopped and the pump primed
go to turn the engine over and it clicks away again and everything on the dash goes crazy rev and speedo needles wave all over the place engine warning like flashes like mad, engine wont trn over
ive given the TPS and MASS sensor plugs a wiggle too, battery is holding 13.4 volts fine
any help greatly appreciated
Old May 19, 2011 | 07:31 PM
RichieST's Avatar
RichieST
Battery clamps tight? Could also check for loose earth points.
Old May 19, 2011 | 07:33 PM
Mr Sam's Avatar
Mr Sam
loosened them and given them a wiggle and tightened them up again, along with the engine earth wire
Old May 19, 2011 | 07:37 PM
Churtz's Avatar
Churtz
Yeh my bet would be an earth point somewhere.
The ecu earths in the NSF footwell.
Matt
Old May 23, 2011 | 06:24 PM
Mr Sam's Avatar
Mr Sam
cleaned all the earths in the engine bay, battery is holding 13.4volts
car starts fine on jump leads off another car, with the engine running the battery is 14.5v so im guessing battery and charging circuits are fine
stop the engine, and again wont start everything dies, stats fine again off jump leads so give it a drive up and down the drive
ABS and traction light come on at 5mph and go off again when stopped, car still wont start off its own battery :S
Old May 23, 2011 | 06:50 PM
RichieST's Avatar
RichieST
Have you tried a different battery? As you say it starts ok but still could have a dry cell or something that could be causing lack of current. I would try another just to eliminate it.
Old Jul 9, 2011 | 08:34 PM
spicey's Avatar
spicey
had the same problem on mine, was the battery that needed replacing
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
hopper350
Sep 4, 2015 12:53 AM
