Obscure mondeo V6 queries
I have a few odd queries about the 2.5 and 3.0 mondeo gearboxes (MTX 75 I believe) if someone can help me out!
Does anyone know if any front drive fords used such an arrangement and may have a compatible outer CV with the mondeo?
Cheers!
- Can the equal length shaft be removed and a CV inserted in its place? It looks very tight for the bellhousing
- Is the box cable shift?
- I assume the clutch is hydraulic?
- Does anyone know if the CVs (either inner or outer) are common with the other MTX75 boxes?
Cheers!
Ebay suggests the outer CVs are completely different, as are the driveshaft splines
Transit:
http://www.ebay.co.uk/itm/FORD-TRANS...gAAOSw4shX4SxO
Width: 120mm Manufacturer Part Number: CV1016N Diameter: 101mm MPN: CV1016N External Teeth, Wheel Side: 28 EAN: 5054259083012 Seal Diameter: 60mm Part Manufacturer: Shaftec Internal Teeth, Wheel Side: 29 Weight: 3610g Overall Height: 200mm Length: 260mm Number Of Teeth, ABS Ring: 48 Height: 120mm ABS Ring Diameter: 104.5mm
Mondeo ST220
http://www.ebay.co.uk/itm/Ford-Monde...QAAOSwqBJXU3ZC
Diameter (mm): 91 Seal Diameter (mm): 53 Height (mm): 155 Internal Teeth Wheel Side: 26 External Teeth Wheel Side: 27
Transit:
Mondeo ST220
