Reverse light and lighter point problem
Bought a KA 2006 recently and as per tittle reverse light and lighter point aren't working.
Checked the light bulbs, there fine.
Took it to Halfords and was told that connector in reverse light is fine
Fuses are fine
Voltage is ok
Repair man told me that it's likely to be the earth points and to get them cleaned but I cannot find any diagrams anywhere, tried google and various forums.
If anyone could point me to where I can find them or what else it could be I would appreciate it.
Fuses are fine
Voltage is ok
You say "voltage is fine". If Voltage is fine at the points then they would be working so I'm guessing its either +12v is present but your having to earth out manually, or the voltage was taken further back down the wires, in which case find the break further up the wiring? (just after clarity)
Reverse bulb earth point in likely in the boot. But its more than likely the reverse switch in the box itself at fault - easy enough to bypass to confirm that tho.
Lighter point you'll have to trace behind the dash as it likely shares a common earth point in one of the footwells. Could also be a dodgy connector, had a few of these come loose.
