Activating cruise control on FF mk1,5 1,8 TDCI
Hello, folks!
Recently I got all what is needed to install cruise control (steering wheel buttons, wires, etc.) and installed them. When I got to the last step, which is enabling cruise control on GEM and PCM modules through ForScan (I'm using ELM327 v1,5) I found all the options I can activate, except for the cruise control...
And the question is: How to get cruise control viewed the configuration window of both PCM and GEM modules?
I noticed that in the "configurate as built" section there's some sort of code. Maybe if someone can tell me what code should I insert, so I can have the cruise-control option showed in the configuration list...
Mine is Ford Focus mk 1,5 1,8 TDCI 2004
It has drive-by-wire accelerator pedal...
Last edited by Atypoc; 07-05-2016 at 05:58 PM. Reason: has to show more details about my car
Hi
I'm contemplating a similar project with my FF MK2.5 2.0L 16V. Could you please post some photos/description how you did yours ?
How did you resolve the activation issue ?
Cheers, Yair
Cheers, Yair
Rob Winstanley
Ford Focus Range
02-03-2016 06:50 AM
