spark plug blown out of head st170
hi I have had a spark plug blow out of the head stripping the thread does anyone know what may of caused this and is there an easy fix.
Aye you can fit a insert to repair the thread, I've known a spark plug work loose on a car after not being serviced for years and that ripped the thread out with it.
Some people seem to think you have to tighten spark plugs with a long extension bar and over tightening can strip the thread. As others have said a heli-coil insert will fix it.
Get it towed, you do not want fuel /air mixture blowing out of the plug hole in to a. Engine bay that will be hot and have areas that could spark....not worth the risk.
