focus rs ecu's and mapping
hi guys,,,prob going to keep the connect now so looking into a few bits
mapped my scoob many many times so i know a bit about it but dont know anything about the frs or whats on the market for it,,or who to go to for good work so a few questions for you all if you can help ;-) can the standerd ecu be mapped ???,,,if so whats the pros and cons,,and cost whats a blue fin ??,,,sorry if im being thick :oops: what aftermarket ecu's are there and there cost's,,,been offered a omex at one point but as i said dont know alot about them who is good with the frs ie mapping it,, doing work on it,,,iv got a very good mapper but he doesnt do any fords,,,he said he could but id rarther go to a proper ford mapper |
Depends which Focus Rs your talking about! MK1 read below:
Yes the standard ECU can be mapped, i know Motorsports Development have done a couple. I believe a live map from them starts at about £500 Bluefin is the name for the handheld device Superchips currently sell, you get the unit plug it in and load the map and its done believe the cost of this is around £300. this is available for mk1 and mk2 RS's Other companies do maps for the Rs as well, Dreamscience are good but Pete at Demon Performance Centre: http://www.demonperformancecentre.co.uk/ can also do remaps and most mk 1 FRS owners take their cars to him he does mk2's as well though, great prices and great knowledge and doesnt rip you off. Mk2 FRS have alot more plug and play style remaps: Revo, Code Red, Mountune, JR racing, Jamsport, Sitech, thats just to name a few sure there are loads more! Aftermarket ECU is not something ive looked at unfortunatly so couldnt give any advise on this! |
jamsport can remapp the standard ecu too, my mate went to them with his rs converted mk1 focus and not had any problems. he recomends them actually
thanks for the help guys ,,,its a transit connect with mk1 rs running gear,,,looks like a live map on the standered ecu is the way ill go as im just after getting the most out of whats there im not going to be modding it to much
well what are your plans for it mate? if its just basic stuff, airfilter, actuator, dumpvalve, exhaust i wouldnt bother with a remap id put it on dreamscience remove the amal valve run it direct with boost set to about 22psi and youve got a great usable power! you can add a hybrid and a tubular manifold and it will be even better.
Originally Posted by Zetecfiesta
(Post 5586710)
Rereading what i wrote what i meant to say was why bother with a livemap, yeah you can spend £500 plus on a live map but a dreamscience unit for about half that will do just fine, im running over 300bhp and got everything i listed above!
is your dreamscience unit a generic map then?
not sure a live map would be as much as £500 to be honest as you'd be starting from a decent map anyway but without calling the tuners i wouldn't know for sure. does the dreamscience plug straight into the focus loom? |
The DS is a generic map and so the likes of the BF and all the other units mentioned...
The problem with the generic maps are that they overfuel heavily! This can result in poor economy and a loss of power (as you probably know)...however, they are a GREAT method for cheap upgrade and hike in power and its what most people use with great success! I normally say anything up to around the 320-330hp, use the DS or BF, anything above, personally I would get it live mapped from MSD as I will be doing myself. MSD are also able to map for bigger injectors and will be able to push the MAF sensor as far as it will possibly go! Alot of people who claim they can map the FRS management, map through a DS unit! I know MSD actually map onto the ECU itself and retain all OEM features Fingers crossed mine will be making its way up to MSD after my inlet, cams and rods are done...ill only be able to comment on how good the custom maps are once thats done. But I can happily compare the DS and BF as I have both units sat here lol |
i will only be live mapping it on the road as i thats what im used to to be honest and its the best way to map a car imo,,,
plans for it are,,not much realy at the mo lol,,,,im not after outright power as iv got a 450+bhp scoob for that,,,,,ill be fitting a dump valve and de-cat ,,inducion kit and thats about it realy as im just after a bit more fun not unusable power thanks again guys all the info i can get will help |
the std ecu can be custom mapped, but not live mapped
there is a diference ;) got for aftermarket i use DTA s60 pro, one of them fitted mapped job lott drive in drive out £1300 GR Performance |
Originally Posted by Rollinz
(Post 5592267)
Custom map around £500, if done properly will see good results, as for mapping road vs dyno, there's nothing wrong with mapping on a dyno and doing some road tests afterwards.
Originally Posted by GUZZLER
(Post 5595940)
(Post 5592267)
Originally Posted by Stu @ M Developments
(Post 5596256)
Your wrong, it can be live mapped.
(Post 5596256)
i wasnt aware this could be done? so you remap the origional unit? or you talking unchip or somthing??? if you can live map the for ecu, i suggest you get onto RSOC in the focus section and get them told cause theres always debates on which is best map to go for, (blufin/dreamscience etc) but if u can live map them, you will get SHED loads of busines |
(Post 5597256)
so you remap the origional unit? or you talking unchip or somthing??? if you can live map the for ecu, i suggest you get onto RSOC in the focus section and get them told cause theres always debates on which is best map to go for, (blufin/dreamscience etc) but if u can live map them, you will get SHED loads of busines There is no other way to live map. The RSOC boys are quite aware that we do this, we have been doing it since the car was 9 months old. |
(Post 5597899)
We EMULATE the original and access it live whilst driving the vehicle.
There is no other way to live map. The RSOC boys are quite aware that we do this, we have been doing it since the car was 9 months old. runing a GT35, custom inlet, and diferent throttle body could you have got the std ecu to work propperly?? |
(Post 5601805)
so for cars such as mine..
Bumping this thread as i have a simialr question. I currently have a mk1 focus 2.0 zetec. Ive just bought a focus rs engine for a conversion. What is the best way to get this running? Can the 2.0 zetec ecu be mapped to suit the focus rs engine? Or do i need the focus rs ecu to start with?
Originally Posted by phil_focus
(Post 5586411)
run it on an Rs ecu and loom or go for an aftermarket ecu.
| All times are GMT. The time now is 01:22 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
