focus rs ap clutch.... help!!!
Old 11-11-2009, 10:28 PM
tezmanian devil
tezmanian devil's Avatar
Default focus rs ap clutch.... help!!!
evening all,
i'v just bought a focus rs ap heavy duty organic clutch kit for my mk5 escort zetec turbo project...
but when i went to fit it to the flywheel, i'v found the bolt's that held my normal clutch on arn't long enough to fit through the ap clutch
which bring's me to my question...
do focus rs's have longer bolt's that hold the clutch to the flywheel? if so, does anyone have the part number for the bolt's so i can get some, the ford dealership round here is crap and they can never get anything
any help with this would be awesome as it's just these bolt's that are holding me up from being able to fit my engine and box
Old 11-11-2009, 10:34 PM
XRT_si
XRT_si's Avatar
I will be fitting the same clutch to my engine saturday so wouldnt mind knowing part numbers either. I have heard they need longer sized bolts before though
Old 11-11-2009, 10:46 PM
tezmanian devil
i'll go down my loacl ford garage tomorrow and see if they can come up with anything.
will let you know if i find out anything
Old 12-11-2009, 11:20 AM
Sp3no
Sp3no's Avatar
Im confused? Do you mean the Fly wheel bolts or the Pressure plate bolts as the clutch itself is not bolted to anything it just slips on the input shaft.
Old 17-11-2009, 12:11 AM
pdfbt40
pdfbt40's Avatar
The FRS clutch cover bolts are FINIS 4105253. K Head M8 x 25mm IIRC.
You do realise that the concensus opinion on this Forum is that hydraulic operated clutches do not fit in the bellhousing of cable operated MTX gearboxes. Especially the FRS with the thick alloy cover plate.
Martin
t230 (26-10-2016)
Old 17-11-2009, 10:24 PM
XRT_si
XRT_si's Avatar
Martin
My Focus RS clutch fits fine with my cable clutch/rod linkage MTX.
Ordered my bolts today so was going to give the FINIS code, they are 95p each by the way
Old 26-04-2013, 07:05 PM
luke19790_3
luke19790_3's Avatar
Old thread but having trouble getting these from ford is there any other options?
Old 26-04-2013, 07:38 PM
pdfbt40
pdfbt40's Avatar
What, pressure plate bolts or clutch plates?
Did you try an AP agent?
There should be clearance, given the AP pressure plate, to use HT bolts if you can't get the k head ones from Ford, if you use a thin walled socket.
Old 26-04-2013, 07:41 PM
luke19790_3
Pressure plate, tried the finnis no above but they aren't in stock at the moment.
Old 26-04-2013, 08:03 PM
pdfbt40
pdfbt40's Avatar
Its an AP clutch. Have you tried looking the number up on AP web site and order from an agent. May have to use a slightly uprated one.
Old 26-04-2013, 08:11 PM
luke19790_3
The ford bolts are fine but they need to be replaced when fitting a new clutch. But will have a look on the ap site.
Also It's a frs clutch/flywheel in a rs2000 box
Old 27-04-2013, 07:45 AM
JamboRS
focus rs 1672
JamboRS's Avatar
Contact graham at carpartsexpress. He'll get you the correct bolts
Old 27-04-2013, 09:57 AM
luke19790_3
Thanks
Old 27-04-2013, 12:23 PM
pdfbt40
pdfbt40's Avatar
The absolute necessity to replace clutch cover bolts is another urban myth like the changing of release bearings/cylinders, hanging over from 60/70s.
Old 27-04-2013, 12:42 PM
luke19790_3
The manual tells you too plus the bolts are quite soft material.
Will the clutch fit in a rs2000 box
Old 27-04-2013, 01:08 PM
pdfbt40
pdfbt40's Avatar
As I said its a hang over from when normal CS bolts were used. Also a CBA for costs of dropping gearbox off again to a Garage. The hardness of the bolts is irrelevent, its the tensile strength and the applied forces. Generally its a retention force not a clamping force, and certainly not a yield strain.
Release bearings use to be a carbon, so unlike a roller bearing had to be considered a consumable. Again, though now a roller bearing and hydraulic cylinder, the manufacturer will recomend replacement each time the box comes off.
CBA says compare the likelihood of failure after 'looking' at it, cost of new assembly, labour cost of dropping box off again.
If you go through the thread, there seemed to be reports that a hyrdaulic release clutch assembly didn't fit a cable operation clutch gearbox. XRT_si said his was OK.
Martin
t230 (26-10-2016)
Old 27-04-2013, 01:38 PM
luke19790_3
The focus manual states that the ib5 bolt can be used again but for the mtx needs to be replaced.
Old 03-01-2014, 10:39 PM
lowman
lowman's Avatar
and even if they are not supposed to be changed...i would change them anyways...its such a little cost when you are doing all that work to change the clutch....so to not change them is just plain stupid if you ask me.
to those how said the bolts do not need replacing..i do not mean that YOU are stupid
Old 12-01-2014, 07:29 AM
Churtz
Churtz's Avatar
Last time I needed some (about 3months) ford had 1 in Europe, and the rest back order wit no date available. I bought the one and then matched it up with a local bolt company ... In fact I went a little stronger with the material.
Matt
Old 10-06-2014, 09:05 AM
De4n0
De4n0's Avatar
Matt
Do you remember the bolt thread and sizes? I'm in need of these bolts.
Old 10-06-2014, 02:32 PM
pdfbt40
pdfbt40's Avatar
M8x30mm. They are a flange head, but a normal head and washer shouldn't be an issue on clearance. 8.8 tensile strength.
studabear (02-12-2016)
Old 10-06-2014, 04:31 PM
De4n0
De4n0's Avatar
Thanks mate
Old 14-06-2014, 10:09 PM
escortzetec turbo89
escortzetec turbo89's Avatar
Default escort zetec turbo clutch
hi can any one help I don't no witch clutch to go for I am running 280bhp I am looking at a 6paddle eather the helix or ap racing or if you no off a better one I want the clutch to be able to handle about 400bhp and I want to uprate my drive shafts on my escort mk6 gti
Old 14-06-2014, 10:11 PM
De4n0
De4n0's Avatar
The focus rs Sachs clutch is popular, worth looking into that, probably looking around £550-£600 delivered.
Old 15-06-2014, 09:39 PM
escortzetec turbo89
cheers il have a look into it
Old 26-10-2016, 01:13 PM
t230
t230's Avatar
I know this thread is waaaaay old but it helped me alot as im about to fit an ap paddle to a 2.0 black top mtx 75 with lsd and found same problem short bolts.
Burton have these for anyone else running in to same problem.
Part number as follows
FP451 - 1.25 "
FP452 - 1.5"
FP454 - 1.75"
Bout 75p each
Old 27-10-2016, 07:07 AM
bigdel
bigdel's Avatar
FP451 - 1.25 "
FP452 - 1.5"
FP454 - 1.75"
Bout 75p each
I have a brand new full face sachs clutch for a focus rs for sale at the moment. £510 + postage. Saving about £60 on the price from DPC.
Message me if you're interested
Sorry just read your post properly and now realise you already have a clutch so ignore the above.😕
But if anyone else is looking for a sachs clutch for a focus then get in touch😀
Old 12-12-2016, 06:41 PM
t230
t230's Avatar
alirghty mate? ..sorry just seen this....i had the clutch already thanks
wowk
30-03-2021 07:49 PM
tankybaby66
06-02-2016 02:24 PM
Sp3no
27-09-2015 07:23 PM
Tank Mike
26-09-2015 08:07 AM
Quick Reply: focus rs ap clutch.... help!!!
