FRS alarm
FRS alarm
when i got my focus i am sure when i armed the RS alarm it use to beep, well now it does but only very very quiet, as in u cant hear it unless u stand next to rear left back lioght (as its in boot) is there some settings u can alter for this?? also heard u can make tham lock as u set off too???
any info apreciated
richard
any info apreciated
richard
Mine is quite quiet too, i think its because the siren is in the boot and behind the trim which dampens it quite a bit. Yes you can set the anti jacking on the car but it is on the car and not the alarm. it comes on all focus's. I have it done on mine but my mate done the procedure for me, i'll try to get him to write it down for me and i can let you know.
Here you go mate.
How To Activate The Auto Lock Facility On The Focus.....
(get in car and lock the door first..then follow instructions)
1. Turn on the ignition to position 2 but dont start the engine
2. Lock the door by pushing in the button below the handle, and then pull the handle slightly to reopen it (Repeat this operation three times)
3. Turn ignition to position 1
4. Lock the door by pushing in the button below the handle, and then pull the handle slightly to reopen it (Repeat this operation three times)
5. Turn on the ignition to position 2 but dont start the engine
A beep should be heard
6. Lock the door by pushing in the button below the handle and then pull the handle slightly to reopen again
A final beep should be heard.
(Note - have a look at the key hole it tells you what position each turn is!)
