charge cooler out of water problem?
if the chargecooler is run with out water or loses its water will this cause damage to the car in anyway???
cheers
cheers
9500RPM torqueless wonder
Question is why would you run a charge cooler with no water? intake temps are going to go up considerably meaning less power and possibly making it over fuel as well?
my mates frs had the coolent pipe split and empty the resivour for the charge cooler, he only noticed yesterday but didnt kno how long it had been like it,
just making sure it wouldnt cause any serious harm to the engine
cheers liam
cheers liam
1 Post
Burst pipe or severe blockage in the system by the sound of it.
Try removing the top hose on the far top right corner of the engine bay, also on the top right corner of the charge box. Then stick a hose pipe into the box and hopefully, it will piss water out of the hose that you removed.
Fill up the chargecooler header tank and pray!
