Focus tdci 1.6 05
Focus tdci 1.6 05
Hi, recently purchased this car and the pipes had blown on it. Ie the pipe from turbo to cooler an cooler to inlet, after disconnecting sensor and changing pipes, she runs fine but after a certain speed or rev a red light comes on and it says "engine system fault" I then turn her off and she is back to normal only until I give her a good drive then light comes on again and limits me to 3k revs n no more!
Has anyone came across this problem?
Also it starts tapping in high revs? Haven't checked out yet as she parked on a hill, will check oil ASAP,
Last service was 4k miles ago!
I've got exactly the same problem on my 06 plate but mine is a 1.8tdci .no fault codes show up when it limits me to 3k revs and I've serviced mine changing fuel filter twice swapped airflow meter turbos fine so now thinking egr is caked up . Mines only done 67k miles.
What's egr mate? I read online something about dpf usualy gets blocked up or it's something to do with the loom or throttle body!
Gona get my pal to plug it in to his diagnostic machine n take if from there ,
If so it could be a faulty turbo actuator control solenoid, that's what happened to mine and when I changed the part the difference was instant !
(This has already been posted and discussed at length in the Focus diesel section)
Mine sometimes revs up to 4k and will fly along nicely but other times the light will pop on and engine system failure shows and that then will crawl on revs past 2k. And won't go over 70! It is fine sometimes an others not.
These valves can be cleaned or even blanked off but when blanked it can some times cause a fault code.
The DPF can cause problems as it effectively bungs up the exhaust but this will be down to how well or often the system is regenerating, the PSA engine and system you have uses a fluid to regenerate and clean the DPF. This fluid is known as Eolys fluid and does need to be refilled once it's all used but I would suggest getting it plugged into a diagnostic machine if you can, it could be a few things and there's no point just "guess" replacing parts !
Interested to see how it goes ?
Ok buddy all done, diagnosed anyways,
Good news is nothing major like feul pump or nething
Computer shows no code or no problems,
To further inspection it appears 1 of the injectors is blown, also the actuater itself is nackered it does move under load , its asif it has seized or somthing so that needs replacing!
All in all not to much to repair as long as injector comes out easily
Just to clarify, will it absolutely only rev to 3k (even in neutral ?) or will it rev freely to that point only then to struggle past it and crawl and I do mean crawl toward the red line
Yes mine will only rev to 3k its as though the cars running without the turbo as it will still crawl upto 80- finally sometimes on a long run it will go off and run perfectly then back in
It's hard to say with any degree of certainty but it does "sound" a bit like the problem I had, the actuator control solenoids use vacuum pressure so the first thing I would do is take the engine cover off and make a very thorough check of all the visible vac lines. A vacuum leek could cause the same symptoms as a failed/failing control solenoid so just make sure it's not a ten pound fix before you start looking at more costly components. Are you familiar with what you'll find under the engine cover ?
Glad to hear it's nothing "too" serious ! The actuators can stick, some times they free up and some times they don't ? But without it operating correctly the car could be seriously down on power, so that and a duff injector could together cause all kinds of trouble so lets hope those things solve your issue ?
I will have another look under the bonnet tomorow as I am quite familiar with what I'm looking at, actuater won't budge, a screw driver helps it move slightly!
Is it possible to lube this actuater or best to replace also if I replace will it need mapping !
You may be able to free it up but you won't know until you try it, if you google or put something like "TDCI stuck actuator" into YouTube you'll get a raft of clips and articles on the subject.
massivewangers
30
01-10-2015 07:40 PM
