2008 1.8TDCi - Engine management light & DTC codes...
Hi all,
A few weeks ago the engine management light came on on my mum's 2008 Focus 1.8 TDCi, accompanied by a whooshing noise under acceleration. I found a split in the pipe coming from the turbo, and replaced that with a genuine part.
It drove well for a few weeks, but now has had the engine manegement and traction control lights come on again. Not sure if the 2 lights are related...
I hooked up my F-Super USB and got the following codes from the PCM:
From the ABS module, I got:
Cheers,
Gareth
- P0402 - EGR flow excessive detected
- P0238 - Turbo/Super charger boost sensor A circuit high
- P010F - Mass or volume air flow sensor A/B correlation
- U2023 - Fault received from external node
Cheers,
Gareth
Stu @ M Developments
41
21-08-2015 06:47 AM
