Exhaust housing bolt conversion thing lol
Hi peeps, was just wondering whats involved in converting the normal nut and bolt job which holds the exhaust housing onto the turbo into bigger bolts....some of mine have snapped off again (about the 4th time now)
also what sort of bolts should be used? thanx for any input :top: :top: bassboy |
i was told drilling out and replaced with M10 instead of M8 studs
dont know thw procedure as universal are doing this on mine now :top: |
cheers for the reply mate...im guessing ill have to rethread the exhaust housing to...hmmmm something that i think ill do if the current 2 studs need drilling out...failing that i heard GumGum on the threads works a treat
any one else have any input on this? bassboy |
What exhaust you running out of interest??
I think lack of flexi joint is the main problem for bolts loosening/slackening off. but not to say it would resolve it. |
vroooom ptsssshmongoose without the flexy bit...3" bore and 4" tailpipe :( getting a custom downpipe once i go ZT so will try to get a flexy bit put in then
taking it all off tomo and see what i can do bassboy |
© 2024 MH Sub I, LLC dba Internet Brands
