Rs turbo cutting out after couple of seconds,
Hi I’m new to this, I have a problem with my series 2 rs turbo, it starts but then stops after a couple of seconds, I havent done anything with it yet as only had it a week but i used to mess about with them years back, I’m pointing towards it being the metering unit, any one had the same problem? Gray |
Was it running when you got it, has it been stood, just give us some history mate
Could be a number of things I had the same issues with mine. |
Originally Posted by Piston Broke
(Post 6786118)
Your first issue is you changed everything not sure why ?, basicly ypu need to calibrate your metering unit to your car. Whats happaning the cold enrichment is giving a rich cold mix but when it drops the fuel pressure as the engine warns its going lean so turn your c0 screw a bit to the right. Ideal when warm with a C0 machine aim for 2 to 3.5
ok mate I will try that, will dig my co2 machine out, it black smokes a lot unless that’s where it hasn’t beem run for yesrs
(Post 6786453)
Check your resistance on the yellow coolant sensor
© 2024 MH Sub I, LLC dba Internet Brands
