Cold Heaters
Old 15-11-2018, 10:02 AM
RSMK4TURBO
RSMK4TURBO's Avatar
Default Cold Heaters
Hi all, can anyone tell me how to sort out the heaters on our car,they seem to only very slightly get warm even when the engine temp is at its normal operating temperature.
Any ideas?
Old 15-11-2018, 10:46 AM
steppy
steppy's Avatar
First check if the flap which changes from hot to cold in the heater box is activating when you move the hot cold switch, if thats ok Try flushing out the heater radiator and back flushing it, the narrow water ways clog up with shite, this may not clear it though depending on the blockage, I've filled various ones in cars with brick cleaning acid for 5 mins to break the crud down then flushing again with good effect but new heater rads are cheap enough anyway and easy to replace
RSMK4TURBO (15-11-2018)
Old 15-11-2018, 12:02 PM
RSMK4TURBO
RSMK4TURBO's Avatar
Thanka for the reaponse,im certain the cold to warm switch is working as it does go from cold to a bit warmer when knob is turned but will double check.
How do i reach or find the heater rad?
Old 15-11-2018, 01:18 PM
steppy
steppy's Avatar
To flush you can jut remove the 2 pipes at the bulkhead and attatch a hose to one of the outlets and blast water through each one
to remove
You disconnect the 2 pipes at the bulkhead look behind the engine to see them, remove the metal sandwich plate that the plastic pipes come through through and the foam, the heater box is under the dash held onto the bulkhead with 2 13mm nuts remove these and you can wiggle the box about to get access to remove the heater rad, to remove the rad from the box look at the side where the pipes go into the heater box you will see 2x phillips headed screws remove these and the heater rad will withdraw, it may be tight due to being surrounded by foam, don't forget to replace the strip of foam when you put the new heater rad in as you will get air passing the rad without getting warmed around the edges
I have done them with the dash in, it is a faff but do able, but to make it easier for yourself you may have to dismantle the dash
hope this helps
where abouts in stoke are you? Im an oatcake eater myself, Pm me if you don't want it public
Old 15-11-2018, 03:27 PM
RSMK4TURBO
RSMK4TURBO's Avatar
Will give it a flush first worth a try, thanks for help mate, and im in Stoke its self.
Old 15-11-2018, 03:40 PM
steppy
steppy's Avatar
Cool there's a few old ford owners knocking around the local area, unfortunately quite alot don't actually drive their cars haha I'll keep an eye out when I'm out and about, im easy to spot my daily is the black sapphire in my avatar
Old 17-02-2019, 10:18 AM
RSMK4TURBO
RSMK4TURBO's Avatar
Update, car has hot heaters now,flushed matrix as above and was full of crap.
Thanks for help.
John Salisbury
08-07-2018 10:21 AM
jay simpson
17-09-2010 10:26 AM
LEE-RS
25-04-2005 07:03 PM
Quick Reply: Cold Heaters
