Half reading rev count
What’s the fix to make it read properly
It’s always read upto 3000rpm with the Adaptronics
Trying to get it right with the new ecu, still no luck...
There used to be a diagram on here for the fix...
Or I’ve read about a screw to adjust resistance on back of rev count?
My clocks are 1990 carb clocks
This is the next option to try...
Although thinking about it I might have gone back to a mfi tacho when I went from cossie management to Megasquirt. I have a relay behind the dash like in that diagram.
slammedorion (16-06-2018)
Cheers for the replies...
Fingers crossed we can get it working right
slammedorion (17-06-2018)
Just had the text to say the top diagram has worked
Rev count fully working
Good news
slammedorion (18-06-2018)
I tried this a while back (about a year) but I couldn't get it to work. Had the zenner diode in reverse as per diagram and the two - pins of the coil along with their dioide. The only time the rev counter moved was when the engine cut out and the needle spiked a little. Otherwise it read 0 all the time. Tried 2 different sets of diodes, no change. Rev counter works but at half revs as expected. Any thoughts what I'm doing wrong?
lukemakepeace
12-11-2007 03:11 PM
mark taylor
26-11-2006 10:12 PM
mark taylor
16-10-2006 12:24 AM
