wolf in sheeps clothing options mk4?
Hi can anyone please tell me what engine swaps are the easiest to
do to a mk4 escort...?
The car is a 1.6 auto but I have a rst lsd gearbox if that helps...?
I'm not looking to do a cvh zvh fiesta or escort rs swap because
I would need a donor car and they all cost around the £50,000 mark
I suppose I could get one for around the £20,000 mark but it would
need to much work...
Any advise is appreciated..
Thanks
Thanks
Ben
2.0 Zetec is the simplest, what are you wanting from it?
Thanks
Thanks
easy and cheap.
Hi thanks for the replys...
do the mk5 /mk6 rs2000 have blacktop zetec...?
its just I was thinking about fitting one of these...
http://www.tts-performance.co.uk/for...-zetec-diy-kit
Not sure if a blacktop engine will fit a escort rs turbo lsd gearbox...?
I'm looking for 200bhp ish if that's possible...
If I were you, I'd go with an ST170 engine on an RST gearbox.
Plenty of scope for upgrade to turbo as you go along and it's 170BHP out of the bag.
Lee
Lee
The rs box will fit on the 170 block but think you have to cut the excess webbing off the sump for the starter what management do you plan running is it going to be na or turbo
Ben
Just stick with a blacktop in it, simple kinda bolt in job on an IB5, even a basic turbo conversion will poke over 200bhp on a stock bottom end.
Hi I've been away with work so not had chance to reply..
Can anyone confirm a few things for me please...
Will this engine bolt to a 1990 escort rs turbo lsd abs gearbox..?
http://www.ebay.co.uk/itm/2000cc-For...wAAOSwEK9T1iDd
I'm planning on fitting this kit if its possible..
Please bare with me as Ive never done a swap like this..
Thanks For any replies / advice
