S2 wont start
Only way I can start my S2 is to crank it over while someone holds down the flap on the air meter:wall: Makes no difference hot or cold.
No fuel is getting to the injectors from the metering head. Anyone got any ideas. Could it be a vacuum leak , knackered metering head , poor mixture. Just changed fuel filter and fuel pump relay. Had new plugs , leads and dizzy cap / rotor arm last year. Still running mfi. Would be glad to hear from anyone who has had similar issues. Doing my head in a bit now:cry: |
I had a similar issue earlier on in the year. Turned out the earth for the fuel relay was burnt out. Took some finding, as its goes up behind the dash.
Checked obvious, all multi plugs connected, cold start valve etc? Fuel filter on the right way round? |
can u hear pump priming?(if not check pink relay under driver side dash) most likely metering head common problem
Hi guys. Brand new pink relay on and pump is priming fine. Just cannot get fuel to the injectors. When I bought the car 2 years ago the plugs behind the inlet manifold were the wrong way round which blew the coolant temp sensor but had that replaced.
Gonna take it back in and see if the co2 adjuster is correct as a recon metering unit is over 700 quid and the fuel dizzy over 400 quid:sad: |
Originally Posted by rsmog33
(Post 6507373)
Lee :top: |
Originally Posted by mentalasanything
(Post 6507376)
EFi...
Lee :top: |
I was sceptical, but now I can leave her standing for 4 weeks with the ECU out and she'll start on the second crank. They just run so much better on EFi, best move I made. Makes sense to give her one last chance on EFi though.
Lee :top: |
(Post 6507384)
Lee :top: |
u can strip down the metering head and do it yourself
Originally Posted by doga-ot
(Post 6507401)
© 2024 MH Sub I, LLC dba Internet Brands
