mfi to efi conversion issue
ust converted my mfi. I go to start the engine and it starts after a while but only holds the revs for about 2 sec and dies. I started it with throttle and will run at higher revs but sometimes will die while throttle is pressed.
Unsure of what would cause this or what to check |
Very difficult to help with lack of info.
Efi meaning frst ofab or ofac I guess? What wiring did you use? How did you convert the loom? Is it using the correct sensors and wiring do they work and been tested. How have you done the trigger for cps. So many more questions before any answers could be given. |
OFAB ecu and wiring all been converted by someone who had done a thread on mfi to efi conversion.
Tigger wheel lined up to tdc with cps around 1mm away. |
Originally Posted by Versus_Creations
(Post 6486827)
Efi meaning frst ofab or ofac I guess? What wiring did you use? How did you convert the loom? Is it using the correct sensors and wiring do they work and been tested. How have you done the trigger for cps. So many more questions before any answers could be given. Lee :top: |
Originally Posted by blackbeautyzetec
(Post 6486854)
Sounds like trigger is in wrong place then. |
I will take a picture later. Should it be lined up to the middle of the gap? I was told to line it up to the right hand side of the gap. Lined up to the tdc mark I mean
90 degree from the sensor @ TDC.
Yup as versus states Trigger angle should be at 90 degrees
1 Attachment(s)
Attachment 54304
I got the tdc lined up to the middle of the missing tooth. I need to check the fuel pressure I think. That picture is from the front of the engine bay btw. So looks 180 |
© 2024 MH Sub I, LLC dba Internet Brands
