go-tech pro stand alone management...
hi guys, im now at the stage where im ready to have my management put on, im curently running on ofac which ive used just running my engine in, i have go-tech pro stand alone to put on, i hear jamsport fit this? i was just wondering if anybody else has or has used this and are jamsport the best people to use? also was wondering what kind of results u guys have got (power wise)? also what else would i need to require before fitting? any help/advise would be great, cheers
Dosent gotec use a hall sensor in place of the dizzy? Which you woulnt have with an efi car?
Gotech mfi/mini x uses the dizzy and hall sensor to tell the position the engine is at, but gotech pro is a little more advanced and needs cps input and will do batch sparks nd fuel as far as I recal. It's a fairly old system now and ages since I had any dealings with it! Someone else put there may have more info on that
In response to the op's questions, jamsport are probably best to deal with this for you as far as I understand it they supplied and fitted the system as a official dealer. (Not sure if this is still the case tho) There are others who are willing to map it out there though. Generally it's best to find a mapper you get on with and fit the management they prefer to deal with Power wise that depends more on your spec and the map than the management, as does what parts you need/want Hope that helps a little |
© 2024 MH Sub I, LLC dba Internet Brands
