zetec turbo clutch problem
hopefully someone can help with this, i got my zetec turbo up and running today but when i tried to drive it out of the garage, i couldn't get any gears at all.
the set up is a cvh flywheel, helix 4 paddle clutch and a standard luk cover. its all fitted in an ib5 box with the correct ib5 release bearing. i ended up stripping the box out this afternoon and it looks like the release bearing is coming off the end of the sleeve that it's supposed to slide on, before it reaches the cover. has anyone else had a problem like this? cheers in advance |
How does the pedal pressure/movement feel?
Paddle in the correct way around? |
I found with a Helix clutch and an IB5 hydraulic box I had to grind some off of the friction plate center (the part with the splines) as it was too 'long' and actually destroyed the release bearing.
2 Attachment(s)
Originally Posted by studabear
(Post 6441359)
Paddle in the correct way around? Attachment 64631 Attachment 64632
Originally Posted by Karlos G
(Post 6441377)
About 5mm I think, a fair bit.
© 2024 MH Sub I, LLC dba Internet Brands
