s2 air leak
Hi all av had problems starting my s2 i was told could be an air leak so i did some checks an 1 thing i came accros was the injectors are quite loose when i grab the red injector pipes an woble them the injectors move with it is this normal an could this cause it not to start
Yes could be the cause
Take your air filter off and see if it really sucks the flap down when starting. If it doesn't no fuel, no start. Have a look your injectors should be tightend with a little plate pushing it down. Don't know for sure if they are completly fasten then |
Hi yes they are fully nipped down with them little plates but they are still loose ish
This weekend i will be around my car then i will check if i don't forget. Somebody here will probably know
© 2024 MH Sub I, LLC dba Internet Brands
