Measuring voltage on ignition coil
Hello guys,
I read somewhere (i think the old Fast Ford tech articles) that it is a good idea to check if you are still getting 12V onto your ignition coil. So i did it with a multimeter measuring 2.? volt and then realised that probably is right as the coil is not always charging. Is it possible to check with a multimeter or will i need a scope for it?
Or am i making a thinking mistake somewhere!
Hello guys,
There is a permanent feed going to one side, which should be +12V (will be more than this with engine running) it is the ground side that is switched which is what causes a 'collapse'
So yes, if you have 2V something is very wrong, you sure you were measuring it correctly
There is an exception to this and that is where 'ballast' ignition is fitted, which you don't.
Martin
Measure from the positive side of the coil to the cars body ground with a multimeter,,and ideally it should be very close to battery voltage. especially important to measure under heavy load
The negative side is a pulse from the trigger source.
