Converted to efi
Converted to efi
Hi all got escort Rs turbo dropped a fiesta efi lump in came as complete engine with loom and ecu as such. what wiring can I get rid of the exiting loom and do both computers go also can I convert my exiting throttle pedal connection.done away with the abs so i take it ill just join the brake pedals up and I'm hoping that's it any help would be appreciated thanks
give dubs44 a ring mate he knows what to remove and can do it very quick
clutch pedal you need either a efi mk4 pedal (xr3i or efi orion) or mod your one?
when getting rid of the abs i dont know what you mean join the pedals together?
you bridge out the abs wire to complete the curcuit to complete the system?
Yea have tried to ring dubs44 but no joy have sent him another msg to ring me as for the brakes they all joined the abs unit so I would have to put a join in as have taken out the abs. Was that clutch or throttle cable clutch shouldn't be a problem as have used my old gearbox thanks for reply
Also have got rid of the abs has anyone else done this is it a case of getting some connections and joining the brake lines couple of other things as well air box which one will I need and fuel wise does anyone no what I gotta do with that i take it modding it some sort of way thanks
