Zetec Turbo Flywheel & CPS ?
I have a silvertop 2ltr zetec turbo engine fitted with the 18 zetec flywheel, but the flywheel seems to be damaging the CPS, I bought the engine already built from a Red S2 broken on here a while ago, any ideas on which Crank position sensor I should be using as the one fitted looks like it is too long ?
Thanks
Thanks
Drop me a text Milesy depending on which flywheel you went for in the end I should have one of each 1800 & 2000 you can have from my donor engines.
Mark.
Mark.
Had this prob with ma zvh ..found out there is a few different length and width 1 s....sure the boy that fixes ma car fitted a fiesta rst 1 ..al speak to him to check for deffo tho...a blew that engine up so its prop still sitting on the broke engines pile lol
