What max power to expect from the escort Rs turbo t3?
#41
Best turbo to use is a cos turbo, do not get a t34 unless you want over 300bhp it's over kill and too laggy, the car would be quicker with a stage3 t3 running flat out with 30/40bhp less
Cut back blades slow down response too, when I researched it every tuner I spoke to said run a 2wd cosworth turbo rebuilt with 360 bearings and would flow a genuine 270bhp and be a lot more responsive than a stage 3 t3
Plus it may say on the net that a stage3 t3 will flow 280bhp but in over 10years of being in the ford scene I've never seen a 1600cvh get near it with one fitted, only ever on a zetec turbo
They make more like 250/ 260 at a push and isn't as responsive as a standard 2wd t3
I got a mint 4x4 t3 for £150 for my zt
#43
Ok cheers mate he wants 400 for it or 350 with my turbo. Is that a good price, no warranty though as he said depends on how it's used . I've messages him now.
I think it's best to get a better turbo before I put my bigger injectors and new ecu on, and then get it all done at once?
#46
Do you mean don't get cut back blades on a t34 or cossie t3 or both? That description I put on before is already done and ready, I just need to click buy cr turbos want 600 odd which I can't afford, should be able to just about get 400 lol
#48
my 2.1 zvh run a stage 3 turbo technics t3 with 2wd cossie compressor wheel and 48 back housing made 286bhp @21 psi on rollers runing at the time with mfi and a fith injector set up i may add it lasted 12 months at 1.5 bar before turbo seals went
#49
300+
My new build is .
EFI block
EFI flywheel
Brand-new STD crank
Brand new Genuine Ford oil pump
King racing main bearings
PEC Rods
WOSSNER pistons
Cross hatch ported head (Big port)
Newman ph4 cam
Newman solid lifters
Newman 200lb springs
Harland Sharpe Roller rockers .
Link G4+storm management .
Been told to go standard 4x4 cosworth Turbo with a 360 thrust bearing ...any opinions ? ..i want a reliable 260-300 .
EFI block
EFI flywheel
Brand-new STD crank
PEC Rods
WOSSNER pistons
Newman ph4 cam
#50
Similar spec to mine but I am contemplating switching to a standard cam profile...i have messed about with the cam timing which made things a bit better but still turbo doesn't come on till a bit late.
#56
Balls Deep!
You don't mention manifolds but decent inlet and exhaust manifolds will see faster spool up times, lower running temps and the same power at lower boost levels than if you were using standard ones.
A reliable 300bhp is not a phrase you can really associate with a CVH... At that power cracking blocks is very very common and cam failures (Yes, even with Newmans).
#61
#63
Rods, Pistons, frs gasket and bolts, dd valve springs and you got an engine that will be ok upto around 350/400bhp
Then it’s just cams and head work after that
#64
300+
The 6258 works Great on a Zetec and not so well on a CVH as ive learnt .. if it's the power of 300/350 then the Zetec is a no brainer ..i bought a forged Zetec with all the right bits for 550 and theñ decided I wasn't going to cut and weld a bracket on the inner wing of the mint shell so opted to spunk a lot of money of getting a cvh forged etc ..youre xr3i/turbo on the other hand that would be having a Zetec if It was mine ..there a fantastic engine once tuebod
#65
I’m going to get mine mapped as is, then start saving for a zt, I already have a mtx box in the garage to use
#66
300+
I ended up with this spec in end .
EFI block
EFI Flywheelwith ARP bolts and CPS.
PEC Rods
Wossner Pistons
Ford Crank .
King Racing bearings.
Brand new s2 Ford oil pump
Gated and baffled sump
S1 modified inlet by A.H Fabrications.
cosworth PF09 TPS
brand new cosworth ISCV
Airtec Radiator
Pace Rs500 style single pass intercooler.
Deka 60lb 630cc injectors
Mac 3 port electronic boost controller.
Fiesta Turbo electronic drive speed pick up (gearbox)
Vauxhall 3 bar map sensor.
Simtek Pro engine management.
Zeitronix zt-2 engine monitor and data logger.
Motor sport Traction control.
Boost By Gear .
AL Developments big port cross Hatch head.
Inlet match ported by A.L Developments.
Harland sharp Roller Rockers.
Newman PH4 cam
200lb springs and solid lifters.
Fiesta Turbo coil pack with fiesta turbo leads.
ND Fabrications over the box exhaust manifold.
ND FABRICATIONS down pipe and bracket.
Mongoose-down pipe back and 3" back box.
TURBO - honeywell Garrett GTX2867R GEN 2.
AP racing cp2000-35 clutch kit.
IB5 Gearbox with Quaife diff shot peened Gears.
Rally design quick shift kit linkage .
AP racing Front brakes.
cosworth 2wd Rear brakes.
Mocal 16 row oil cooler
A.H Fabrications breather catch can.
mk5 escort clutch peddle and billet quadrant
EFI block
PEC Rods
Wossner Pistons
Ford Crank .
cosworth PF09 TPS
Airtec Radiator
Boost By Gear .
Newman PH4 cam
muz
16-08-2015 12:57 PM
