Black top zetec inlet conversion
What throttle cable does everyone use? It's in a fiesta so already have the efi pedal? Part number would be great ?
I'm going to get all the bits to do a pedal conversion tomorrow so could get it all at once?
And has anyone got a erst .48 rear housing for sale?
Your using a black top inlet manifold and TB? The fiesta cable wont fit. You can use a mis-match of parts to make it a frs inlet tho which will work. I've got pictures if you need.
i will have a look, so its either my throttle bodie or a mondeo blacktop zetec one
im not bothering with frs throttle bodie as nigel b ran 2bar with a gt28 through a blacktop zetec before it started to struggle
im not going to run that, more like 1.5 bar on a 4x4 cossie t3
http://www.fiestaturbo.com/forums/fi...76357/page735/
Spacer plate routes the bypassed air correctly so that the iscv will work Pictures is jsut over half way down the page on my macbook
I used a focus rs inlet/throttle body and a xr3i efi cable and pedal, I cut the throttle cable bracket down on the throttle body and chopped a 3i efi bracket down and made a hybrid bracket. My mate welded it up and it works a treat. Can get a picture if needed.
Yes please!
