motorsport devloppement evolution chip
hy guys i received the evo motorsport devlopement chip no limit boost
i install it in a standard ECU i did the correct wires connection like on the picture an instructon that i became with ....
the car run 30 second that cut no ingnition any more no spark plugs firing
then i was thinking the ecu was dead because it was long stored in a garage put the chip again out (put again the middle pin togheter like standard ) try it and nothing again
well then i try on a ecu with a turbosystem chip already inside but limited at 18psi i called devloppement motorsport two ask if i can have to chip in one ecu they answer me YES
instal it try it and then engine did exactly the same was running for 30 second an then cut off
well whats is it ???? and what are the 2 botton on the chip up down....
thanks
thanks
yes red wire + on the left hand pin the blue wire up from the middle cutted pin the orange wire down of the middle cutted pin and the black - on the right side
Balls Deep!
So to be clear...
It's the same with a standard ECU, it's the same with the Turbo Systems ECU and it's the same when you try with the MSD 'chip'.... So it will not run at all now?
If so then it sounds like a coincidental problem, maybe with the distributor (hall sensor) or the green wire that triggers the coil.
no i think if i reput a standard ecu the cars will running i was this
at FIRST:
took a old stored ecu put the chip in installed it the engin runs 10 second and then cut of no anymore firing
i was thinking the ecu is dead because longtime stored in a garage
then installed an other ecu in the car the car runs ok this ecu is good so i installed the chip inside and i did the same like 10 secondes running and cut off no firing
like if the chip burns my 2 ecu????
well i gonna ship the ecu to the devlopement ....
at FIRST:
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
