s1 rs turbo only runs with flap held down. ?
What is causing this. Week pump maybe. ? Needs setup now but need to be able to drive it to Essex for that to happen. Stacey
Do you mean the metering unit flap ? if so is there a air leak check all boost hoses for a split , dump valve diaphram , check the idle screw is there (ive had one of them fall out & it wouldnt start ) the flap sucks down but if there is a big air leak it wont pull down & give the injectors fuel. Ive not worked on a rs turbo for years but had my fair share of trouble with them lol
big_Rad
15-09-2017 09:36 AM
Matt Baxter
16-09-2015 08:30 PM
