MTX conversion what linkage? more problems starter to?
Old 25-04-2013, 06:22 PM
jessie_rs
jessie_rs's Avatar
Default MTX conversion what linkage? more problems starter to?
What linkage is used when doing an MTX conversion? im using a mk1 focus rs box with dave mac driveshafts.
Thanks in advance
Old 25-04-2013, 07:00 PM
studabear
studabear's Avatar
focus rs with the relevant cables I would imagine.
Old 25-04-2013, 07:08 PM
haz87
haz87's Avatar
As above. If you've gone to the effort to fit that box, use the proper cable linkage that works with it
Old 27-04-2013, 08:37 AM
crazycage
crazycage's Avatar
it will work fine with normal 2.0l focus or any any mondeo ones as long as you dont try to mix mondeo cables with focus gear stick ect so as long as the cables and stick are from same car you will be fine .
brand new focus rs cables are £93 from ford
Old 27-04-2013, 06:19 PM
scott1986
scott1986's Avatar
thinking bout doing this what drive shafts would I use
Old 30-04-2013, 11:59 AM
jessie_rs
jessie_rs's Avatar
dave mac custom drive shafts would be best
Old 30-04-2013, 02:33 PM
scott1986
scott1986's Avatar
who never heard of him. is he on here ?
Old 04-05-2013, 08:42 AM
jessie_rs
jessie_rs's Avatar
Currently struggling with it now. Ive got a mk1 focus rs box, Focus rs cables and gear stick unit Ive mounted the box to the block but I have nowhere to mount the starter motor? Im running a U.S. zetec turbo are these blocks different to black tops and silver tops?? because I cant mount the starter at the rear without removing a huge chunk of the engine block!
Old 04-05-2013, 12:00 PM
rsmark86
rsmark86's Avatar
I thought it should just bolt up ?
My mtx set up is front starter and on the silver top just bolts up
Old 04-05-2013, 01:22 PM
jessie_rs
jessie_rs's Avatar
It does bolt up but focus rs boxes are rear starter and theres no room for the starter i need to find out what this block is because i think its differen from silver and black tops
Old 04-05-2013, 05:14 PM
rsmark86
rsmark86's Avatar
Not good
Hope you get it sorted,
Old 05-05-2013, 09:46 PM
project rs
project rs's Avatar
it sounds like you've got a 2.0 litre american cvh not zetec and the way to tell is position of oil filter as its further over on the zetec to give space for starter to fit any pics youve got would help
massivewangers
30
01-10-2015 07:40 PM
IainRS1700T
25-09-2015 06:44 AM
cossirob
16-09-2015 07:39 PM
marky_g
12-09-2015 04:26 PM
cossie09
10-09-2015 06:56 PM
Quick Reply: MTX conversion what linkage? more problems starter to?
