fault code 59 after efi con
hi all,
i am struggling with this problem for some time now. i had converted to efi as rs bible and other sources says. i use ofac and xr3i loom.
after moving pin 8 to 27 i get fault code 59 (CO potentiometer out of range). potentiometer is good. when i swap it back this code dismiss.
is it really necessary to move those pins?
other problem is, when engine is cold it smokes a lot (rich) after feww seconds it's ok. can it be all related?
I'm about to convert mine, after all the reading I've done, I was under the impression that using the xr3i loom and ofac ecu that swapping pins was not necessary?
That's the set-up I'm going for too.
i moved pin 27 back to pin 8 and it runs fine and the co pot works now my emissions are bang on ,the other way it did nothing and the emissions were all over the place.
recently i found that my 0FAC works fine when pin 8 is in pins 8 position and pin 27 is moved to pin 45.
then i have no fault codes and in works fine.
Si B
12-09-2015 06:49 AM
