series 1 RS turbo
Engine starts from cold, will not start again after a few minutes running, engine not up to temperature? any ideas?
Air leak?
Try taking ain't box off and give metering head a poke while cranking.... If it starts up its obvious you was not getting fuel..... Only thing is could still be a number of things.... Fucked metering head, air leak or could even be too much fuel by a leaky cold start valve... Very diffcult to fix unless you have a systematic approach trying ONE thing at a time and noting results... Are there any other running issues with it? Good luck |
Originally Posted by atki
(Post 6066797)
© 2024 MH Sub I, LLC dba Internet Brands
