series 2 set up
series 2 set up
hi, finally got my escort bk on the road after along wait, runs ok but would benifit from a proper set up adjust fuel meter unit etc etc live in stafford can any1 recommend someone locally that might be able help and typical cost any help would be great
cheeRS
cheeRS
setup
nms £170 pus VAT and jano oddkiddcreations £50 but jano you gunna spend £60 fuel getting upto him and back then pay him £50 setup but he is spos to be really gd im gunna take my car up to him cuz iv just bought a metering unit from him.
thanks for the response all helpful
didnt want to travel too far till it was set up properly but also just noticed may have a problem with the fuel metering unit so need to sort a replacement first the joys lol
problem is its a nightmare to start from cold turns over for ages and with throttle will finally start, if you then turn it off and try it again it will fire up staright away and start ok every time until you leave it for a few hours then same prob again tried unpluging cold start makes no difference?
any help with this would be great
Ask me a question!
You will only know if you have metering unit issues if they are fairly obvious. The reason i say this is that some of them can work for months and years before they need to be setup again. Some take a matter of hours or days.
So it really depends how good the metering unit is.
Hi I had exact same problem with my rs, I changed both the cold start valve and temp sender on back of the inlet and it started a little better but still not good at all from cold then started running on 3 cylinders, I changed the plugs to denzo uranium plugs today and she starts first turn everytime now, best £40 I've spent on her, hope this helps a little and you get the cold start sorted mate
