Tubular manifolds
#42
yeah it takes a bit of working out, funny watching people follow the pipework
one fella at central day trapped off with 'whats the oint of sticking turbo bodykit on a shitty xr3'
then went on about the ins and outs of xr and s1 and how you know a turbo'd engine from a n/a engine and so on
did make me laugh
did make me laugh
#51
It Wasnt Me!
Gus - your new mani is a magnex XR2/3 manifold modified from the collector to accept the turbo
I binned the exact same one that was on the green shed when I broke it oops
Pulse speration is basically dividing the manifold into 2 banks (if 4 cyl) i.e. cyl 1 & 4 and cyl 2 & 3 are grouped together if the firing order is 1-3-4-2. #1 is ending its firing stroke and opening its exhaust valve while cylinder #2 still has its exhaust valve open (on overlap) so #1 will pressurise cyl #2 whereas if you seperate the manifold so #1 can't interfere with #2 ALL the gasses from #1 will go to the turbo to help spool up time at low RPM's but the turbo must be pulse seperated also, here's an example of a pulse seperated 2wd cosworth manifold
#53
It Wasnt Me!
Rogeboy - Yes turbo is retained in the original pos with ava manifold
AS tubular, not so sure it's of any benefit over standard manifold other than it looks good.
#54
Well longer headers will help shift peak power up the rev range (longer inlet also needed to make the most of it)
Heat will be taken away from rad and IC as these are problems in rs turbos thats a good thing
You may lose thermal efficiency and will take longer to fill the longer mani before it spools the turbo (talking fractions here) so if you heat wrapped the manifold to keep the temperature up, that will help the turbo to spool up quicker again. (remember hot gasses expand more than cool ones, hot gass= more pressure = faster turbo spool up)
A really well designed manifold is worth its weight in gold, properly timed exhuast pulses etc help promote cylinder scavenging etcetc.
Rob,
#56
It Wasnt Me!
Sort of mate, but the other way round. Short headers are good for high rpm power, longer headers or manifold runners offer superior low down power sacrificing top end as a general rule of thumb.
Rob,
Rob,
Look at Focus ST170 for instance, long exhaust manifold, variable length inlet and ofcourse as a result it revs higher to make the 170bhp.
Short manis are good for low down turbo spool up, but you need the length for peak power at higher RPM, look at ava's manifold designs, as long as they can be!
#57
Bodger of Blackburn
i'm afraid rob got it right, longer runners for low down torque as it speeds up gas velocity due to more continual vacuum.
been looking into this as it happens and isn't too difficult to get something to function, but i'd just make a sacrifice in the powerband and just chuck in more boost. VML would be a benefit, but depends what level of tune you're after.
#58
It Wasnt Me!
I'm talking about peak power high in the rev range - which means you need long headers inlet and exhaust.
if you want low down power, then yes shorter headers........
#59
It Wasnt Me!
Ok, so why do all cars that exceed 'normal' rpm's (i.e. higher than 6500) in order to gain bhp have long exhaust manifolds?
Integra type R for instance:
Focus ST170, TypeR's, motorbikes...
Revs = more bhp
Revs = more bhp
#61
Because the "long" tubular exhaust manifold is better than a restrictive cast iron manifold.
The same tubular exhaust manifolds work great at lower than 6500 rpm also.
#63
As above mate, inlets are straight forward (ish) regards to short and long runners. Exhaust manifolds are similar, but have to account for a number of other factors too, I wouldn't really say the integra manifold had particularly long runners compared to other lower revving cars...
The longer the pipe (keeping the diameter the same) the greater the restriction, however with a properly designed manifold you need long(ish) runners to take advantage of cylinder scavenging (extractor effect), which is why that manifold looks like that.....
Rob,
Rob,
07-10-2015 12:56 PM
caprixpack
25-09-2015 07:53 PM
wheelwizardrefurbs
21-09-2015 06:42 AM
Si B
12-09-2015 06:49 AM
