Efi conversion what's needed
It's a mk3 carb escort I'm looking to covert.
First off do I have to have a efi tank? Or will a mfi injection tank work What's needed in the conversion, and can I use a mfi engine with the efi. With an inlet adaptor. And if I do use the Rs turbo mfi engine what else is needed efi flywheel? How easy is the engine look |
Just seen the tread at the top but need to know about fuel tank,
Also if the xr3i loom is used do you need to add anything to run the map sensor for the turbo |
which efi system are you planning on using?
Use a mfi tank.
About £100 new |
Ofab as I would want to run around 1.5bar on a t3 with beige injectors. And 195 chip
So I need a s1 tank fuel pump and lines and filter with efi fuel line to rail for fuel system |
s1 or s2 fuel tank
make sure you use the right filler as well standard rst lines will do you to the engine bay you sure beige injectors will flow enough? they arent that big |
I'm only after 180bhp when I think about it,
Ive just been offered a big valve full race n/a head and as I already have a 1800 zetec bottom end, so with my carbs burtons recon it will be 160bhp just with n/a |
Had a look round your new motor at FF today, very nice Mark! :king:
Originally Posted by Karlos G
(Post 5573667)
im saving for a wedding so cant spend much, |
| All times are GMT. The time now is 05:39 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
