Getting me car mapped :-)
Old 15-03-2011, 08:13 PM
RSricRS
Long live the ford RS'S
RSricRS's Avatar
Default Getting me car mapped :-)
Alright lads as above the car is booked in for the 23rd april to be mapped and can't wait!
Here's the spec:
2.0ZVH
efi
yellows
newman zvh phase 4 cam kit
port and polished head work
forge pistons
zetec rods/ arp bolts
2wd cossie t3/ 360 thrust bearing
pro alloy fmic
airtec rad
Not sure on how much boost pressure shall be being run, not wanting silly amounts just to keep it reliable and a good drive.
So what you reckon lads? Graph will be posted up when its all done
Old 15-03-2011, 08:15 PM
jamie rst
jamie rst's Avatar
who you taking it to then dude
Old 15-03-2011, 08:17 PM
adduk
adduk's Avatar
Good news mate,who is doing the work for you? Have you got a power figure in mind?
Oh and did you get a sunroof in the end?
Adam
Old 15-03-2011, 08:20 PM
RSricRS
RSricRS's Avatar
Its going up north mate, the guy who sorted the base map out etc is doing it pluss he knows the car so it seems right in just sticking with mark.
Mark is a good mate of karls (special k) who built the whole car.
Old 15-03-2011, 08:24 PM
RSricRS
RSricRS's Avatar
Adam
Automark in middlesbrough, i will be happy with a strong 230bhp.
Yes mate got a sunroof sorted lol, should be here tomorrow massive thanks to mattseries2, sound guy.
Old 18-03-2011, 09:50 AM
jessie_rs
jessie_rs's Avatar
what are yellow injectors rated to? i thought they were similar to beiges?
Old 18-03-2011, 11:08 AM
Rogeyboy
Rogeyboy's Avatar
Sounds a good spec and i would have 230bhp should be acheiveable, good luck and show us the graph...
What management is it on?
Old 20-03-2011, 09:34 AM
RSricRS
RSricRS's Avatar
It's running cossie l6 management, I'll be happy with 230 plenty quick enough for a s2
Old 20-03-2011, 09:35 AM
Rogeyboy
Rogeyboy's Avatar
Yeah i should think so, im loving mine atm with 150-160bhp...
Old 20-03-2011, 09:39 AM
mattseries2
mattseries2's Avatar
Cheers Rick.
Bet you cant wait to get her mapped!
Old 22-06-2011, 07:28 PM
RSricRS
RSricRS's Avatar
Well lads better late than never lol
Cut a long story short the car went to jano's and am very pleased with the result, it pullls really well through all the gears pulls well in 5th! it drives great only running 15psi
Haven't got a graph but am wanting to put it on the rollers but not sure where to take it?
Ric.
Old 22-06-2011, 07:51 PM
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
traitor !!
Old 22-06-2011, 07:56 PM
RSricRS
RSricRS's Avatar
Originally Posted by -beefy-
traitor !!
Traitor... i think not.
Beefy you dont know what went off, well you probably do as karl probably told you!
Wasn't happy.
Old 22-06-2011, 09:00 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Sounds interesting... What happened mate?! lol
As for what dyno, just take it anywhere with a dyno dynamics rolling road make sure they use a proper RPM pick up and shoot out mode 4f (IIRC) and the results will be fairly widely accepted as accurate... or as accurate as a RR can be of course.
Old 22-06-2011, 09:04 PM
russ rs
russ rs's Avatar
I was debating where to take to myn so this sounds interesting
Old 22-06-2011, 09:13 PM
RS500nob
RS500nob's Avatar
This may sound hard to believe, but back in the 1990's i owned an S2 black RS Turbo with a Collins stage 1 chip,taking the car to 195 bhp.It also managed 50 mpg on a run if driven sensibly,and to this date was one of the most economical cars i owned.Also at the time i had an Astramax diesel van which was LESS economical than the RS.When i sold it on,the new owner had to put the standard chip back on the car for insurance purposes,and the MPG returned to about the low 30's.I currently have an E36 3.0 M3 BMW,which is also "chipped" to around 340 bhp,and on a run i can get 40mpg!
Old 23-06-2011, 08:04 PM
RSricRS
RSricRS's Avatar
Its a long story mate, Don't want to start slagging folk off on here.
Jano put a set of greens in too!
Old 23-06-2011, 08:39 PM
-beefy-
-beefy-'s Avatar
Wasn't happy.
ok that was a bit harsh i guess , and prob gave the wrong vibe to my comment ,
but imo you should of brought it bk up to mark for final mapping fella ,
i didnt get the full ins and outs from k but i know neither of them were to happy when u said it wasnt coming bk ,
feel free to pm me and highlight any issues i may have missed kid
beef
Old 31-07-2011, 08:34 AM
RSricRS
RSricRS's Avatar
Well... Here's the graph am happy with the results good power/torque for 14psi
Old 31-07-2011, 01:11 PM
Rob_DOHC
Rob_DOHC's Avatar
Lol, i was a believer until you said your 3.0 m3 was "chipped" to 340 bhp... then i stopped believing. You can't even remap a 3.2 evo and expect 340.
But any way,
Glad the OP got his car mapped, shame it didn't go back to the builder/ original mapper... but thats without knowing the ins and outs.
Rob,
Old 31-07-2011, 02:28 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Well done mate!
Any idea why they mapped it so rich after around 4250rpm?
Old 31-07-2011, 04:43 PM
RSricRS
RSricRS's Avatar
Well done mate!
Cheers pal,
Not sure why it's a bit rich after 4250, jano might have some input.
Only took it to just under 6000rpm in 4th I've had it going to 7k on the rev clock! And didn't hit the limiter...? It does get scary when the loud pedal starts vibrating like fook!
Old 31-07-2011, 05:02 PM
studabear
studabear's Avatar
It most likely hasn't got a rev limit set in the map
Old 31-07-2011, 05:06 PM
RSricRS
RSricRS's Avatar
If that's the case then no wonder I can't find it lol.
Old 31-07-2011, 05:07 PM
RSricRS
RSricRS's Avatar
Anyone else have vibration through the loud pedal when right high up in the revs?
Old 31-07-2011, 05:19 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Cheers pal,
Will be interesting to know, Lambda 6.8 is 10.0:1 AFR which is crazy rich.
Did Jano map it then mate?
I dont get any mate no.
Old 01-08-2011, 06:54 PM
RSricRS
RSricRS's Avatar
Yes mate, well.. a guy called paul hill mapped it who helps jano out when hes busy. Good bloke knows his stuff.
I'll have to look into it lol.
Been looking at the map today and as you can see it has full boost 3k!!! But as jano was mentioning to me earlier it drops up and down up the rev range? boost leak?
Old 01-08-2011, 06:55 PM
RSricRS
RSricRS's Avatar
Shit i quoted that wrong! tit.
Old 01-08-2011, 08:30 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Thats ok I get what you mean mate! lol
Well either Paul Hill has an incorrectly calibrated WBO2 or he likes bore wash! lol
Old 01-08-2011, 09:03 PM
RSricRS
RSricRS's Avatar
I wouldnt go as far as bore wash! lol. just a tad rich up the rev range dont have to worry about pinning the loud pedal
Old 01-08-2011, 09:12 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Ok maybe not bore wash but it's very rich! lol Your also down on power and wasting fuel.
Old 01-08-2011, 09:22 PM
Rob_DOHC
Rob_DOHC's Avatar
Paul Hills routinely maps very rich from what a few friends have had done. Its just easy to get the job done i guess, also trys to charge you more than Jano quotes sometimes.
Old 01-08-2011, 09:30 PM
Karlos G
Balls Deep!
Karlos G's Avatar
IMO Rob thats just lazy, map it rich rather than spending the time to get that fine balance between power, det and a good AFR.
Like mappers who just adjust the top line of the fuel/advance tables on OEM ECU's to accommodate higher boost rather than rescaling the tables properly...
big_Rad
15-09-2017 09:36 AM
manuel boeckx
13
03-10-2015 02:29 PM
kosienutter
31
22-08-2015 09:55 AM
track.focus'd
12-08-2015 05:53 PM
Red_bull
09-08-2015 08:34 AM
Quick Reply: Getting me car mapped :-)
