s2 is a bitch too start when cold????
hey chaps, my s2 is a proper pig to start when cold. but once running and warm it is sweet as....
anyone know what the problem could be???
many thanks gary
many thanks gary
yeah ive done that gav, but its still the same mate.. im there trying it so long some times the battery dies... i end up jumping it off my van, it will start tho but just takes forever... im just getting wound up with it now... i just want to get in it and it starts straight away hot and cold..
Warm up regulator not working properly would cause this issue on a 3i, pretty sure the RS uses a similar set up so this may point you in the right direction. The cold start valve, i believe, sprays more fuel when cranking in low temps.
i have the same problem mate on my s2 it does my head in every day but i am the same as you mate dont have a clue why its doing it the lads on bbs have been very helpful but i have not sorted it yet they did say to take it to get it set up properly so i will be doing that towards the end of the month but if it sorts it out will let you know
http://bbs.rsownersclub.co.uk/showth...16#post2509316
when i spoke to power engineering last week they told me that the brown thermotime sensor at the back of the inlet manifold controls fuelling to the cold start valve,and that it gives it about 3 seconds of fuel.
maybe worth a try replacing brown thermotime sensor.
its the one next to yellow sensor at back of inlet
I think the warm up regulator is the same thing as the thermo time switch (check Motorsports Developments guides). This controls the cold start valve and tells it to inject more fuel if required whn cold.
Mine works backwards to that lol.
First turn when cold (with foot on accelerator) but when warm whatever it try it takes 5 -10 seconds of cranking. still starts though, everytime. and it has a very expensive head on it so i'm hoping the fucker isn't warped before anyone mentions that
I'll jump on the owners club then copey.. It won't even start now, I've changed the dizzy cover and rotor aswel as plugs.. It's really getting on my nerves now..
I've changed the thermo time switch and still no luck.. Next on my list is coil and leads, if that don't work then it's sell it or convert to efi and gotec stand alone management..
That seems like an expensive way of just getting it to start.
Why dont you take take it to somone that knows what they are doing first to determine the problem cos if it aint starting now it still may not start after going efi.
true kermitt, but i just want the thing to work now...
im going to have another look at the weekend if, i still
cant start it then ill get it taken to jano, at oddkidd..
hey mate, yeah all sorted now... i ended up taking it to jano at oddkiddcreations, he put a new metering unit on it for me a played with some other bits and its proper sweet now... just goes to show how much trouble a metering unit can cause..
wot jano said...lol...
i have to go back to jano's to sort out my rattley exhaust and get it to idle better,
other than that she's good as...
