Adjusting clutch pedal travel
Can you adjust the clutch pedal so it sits higher up and pulls the cable more? If so how?
I am still having occasionally selecting gears normally coming down the way and have to double clutch to get into gear which is a PITA.
I should add its an uprated Helix clutch with new quadrant fitted to the pedal.
Pretty sure there's no way of adjusting the pedal, my mk1 orion has a very high clutch which I hate, clutch is new, as is cable and ratchet, but I can't sort it. Are you sure your ratchet is fitted correctly? If the pedal is too low, could be possible to move the quadrant round a click or 2 manually, perhaps?
just the quadrant, clutch arm on the gearbox, and clutch are new. Have not replaced the cable so maybe it needs doing too. The clutch is not a paddle so never saw the need to do the pedal conversion.
i just figured cos i have a splined shaft coming out the top of the box and the clutch arm has teeth it would be a case of moving the arm further forward by rotating it round another spline on the shaft.
so did i but from the looks of things it may be adjustable on the splines. Am gonna change the cable first though as i dunno how old it is then will have a better idea.
sure I remember jano saying it shouldnt be moved, see how you go with the cable.
I ended up changing my pedal and quadrant, wasn't too much of a ball ache
