Should fan wires be live?
Old 18-01-2011, 07:54 AM
stevealien
stevealien's Avatar
Default Should fan wires be live?
Hi chaps
need to rig up my twin Rad fans.
I put a meter on the fan connector plug next to the rad too see which one was live and earth but neither seem to he live.
I had the ignition on but car not running.
I'm guessing one of them should be live.
Checked fuses and they fine
put a meter to the fan fuse and it's live.
Am I missing something here ?
Do they only become live when up to temp ? As I thought the earth was switched by the fan switch.
I'm sure one of you geniuses could explain this to me
cheers peeps
Old 18-01-2011, 11:39 AM
luke19790_3
luke19790_3's Avatar
without looking at the manual, the 12 volts must be switched by fan switch
Old 18-01-2011, 11:45 AM
luke19790_3
just checked a fiesta rst manual is a black cable from the fuse box to the fan switch then black and red to the fan,
Old 18-01-2011, 12:16 PM
stevealien
stevealien's Avatar
Does that mean that one of the wires to the connector should be live and the fan switch switches the earth ?
Old 18-01-2011, 12:29 PM
stevo123
stevo123's Avatar
I always was under the impression it went like this:
earth--[-BATT+]---[fuse]---[switch]---[fan]---earth
Old 18-01-2011, 12:37 PM
rog
rog's Avatar
Sorry to wade in but in most cases the earth is switched, so the +ve should be permananet live.
Old 18-01-2011, 12:47 PM
DazC
DazC's Avatar
From memory, RS Turbos are switched positive and Cossies are switched negative.
Old 18-01-2011, 12:54 PM
rog
rog's Avatar
Ok looks like i was feck all help!
Old 18-01-2011, 01:34 PM
stevealien
stevealien's Avatar
so i need to get it up to temp to see if the wire becomes live once the switch cuts in????
Old 18-01-2011, 03:47 PM
luke19790_3
when hot the temp switch operates which supplies the fans with 12volts.
You can unplug the switch and link the two terminals in the plug which will do the same thing.
Old 18-01-2011, 03:53 PM
RichieST
RichieST's Avatar
As above, bridge the fan switch wires, that will bring the fan on.
Old 18-01-2011, 06:28 PM
stevealien
stevealien's Avatar
Well I've run the car to warm it up and one of the terminals becomes live once the temp gauge gets just above halfway.
Thanks for your help guys.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
IainRS1700T
25-09-2015 06:44 AM
jay030787
18-09-2015 04:38 PM
Quick Reply: Should fan wires be live?
