Oil Return, Elbow pipe.
Old 13-01-2011, 07:23 PM
Rogeyboy
Rogeyboy's Avatar
Default Oil Return, Elbow pipe.
I currently have a samco elbow acting as my return, what i want to know it will it be ok temps wise, once the oil gets mega heated by the turbo is it gonna melt the silicone pipe and split?
If so... Is it possible to get this return elbow made up from samco or roose etc, with a heat resistant silicone...?
Old 13-01-2011, 07:25 PM
Karlos G
Balls Deep!
Karlos G's Avatar
If it is fluoro lined it will be fine, if not then yes I know Roose do one, cheaper than the Ford one at £45 too!
Something like this http://cgi.ebay.co.uk/22mm-Silicone-...5480c4fff77b3c
Not sure if 22mm is the correct diameter but you get the idea!
Old 13-01-2011, 07:27 PM
mr_joe0606
mr_joe0606's Avatar
this what you need?
https://passionford.com/forum/ford-r...turn-pipe.html
Old 13-01-2011, 07:57 PM
Rogeyboy
Rogeyboy's Avatar
Cheers Karlos - I'll speak to them people, 180c is that gonna be a hot as the oil gets exiting the turbo? That the temp limit on that pipe.
Joe i saw that, and its a good deal but i'd rather a silicone/uprated part - fit and forget etc?
Old 13-01-2011, 08:00 PM
mr_joe0606
mr_joe0606's Avatar
the one i had on mine was orignal from ford fist time replaced was today in 22 years.
Old 13-01-2011, 08:01 PM
stevealien
stevealien's Avatar
make sure you get this right mate.
i set my rs on fire using the wrong pipe.
the heat from the turbo melted the top of the centre of the return pipe and the oil caught fire setting my bay alight.
Old 13-01-2011, 08:24 PM
Rogeyboy
Rogeyboy's Avatar
Yeah i had a brand new ford 1 split after 3weeks dropped 1/2 my sump all over the road, luckily enough it was 200yds from home... £65 on the hose down the drain!
Got a piece of samco on there atm, its holding up (longer than the ford shit) so far.
Just wanna replace it with something uprated and properly designed for the job, cause when i drive it atm it popping the bonnet when i stop to check the return. Piece of mind really!
Old 13-01-2011, 08:29 PM
stevealien
stevealien's Avatar
theres a guy selling some in the for sale section mate
Old 13-01-2011, 08:31 PM
stevealien
stevealien's Avatar
oh think there ford ones lol.you dont want them do ya.
i ended up with a braided on on mine but cant remember where i had it made
Old 13-01-2011, 08:35 PM
Rogeyboy
Rogeyboy's Avatar
Well if i can't get an uprated one i'll have to get another ford 1...
Gonna check out Karlo's EBay seller and see what they can source for me!
Old 13-01-2011, 09:07 PM
orionmojo
orionmojo's Avatar
Roger you need to use expanding clips to secure it, jubilee clips will make it split prematurely as they dont let the rubber expand normally with the heat.
Old 13-01-2011, 09:31 PM
Rogeyboy
Rogeyboy's Avatar
Ahh, now that could be worth a try as i did use jubilee's!
Old 13-01-2011, 10:06 PM
Puss2
Formerly know as Puss
Puss2's Avatar
Ive had one from roose on mine for ages its been fine £22 from memory
Old 13-01-2011, 10:22 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Was just about to say this!
Old 14-01-2011, 10:21 AM
muz
Wye Valley Hardcore
muz's Avatar
I thought hot oil caused silicon to break down unless it Flurolined and you get silicon shit in your oil and eventually split? I think everyones covered the options though. I've got a new Ford one to go on.
Old 14-01-2011, 11:53 AM
Rogeyboy
Rogeyboy's Avatar
Yeah its looking like i'll go with a Ford one again and use the expanding clips I take back my slagging off of Ford's oil return hose!
Gonna look into a fluro lined silicone aswell...
Old 14-01-2011, 09:00 PM
Puss2
Puss2's Avatar
The one from Roose is made for the job
Old 15-01-2011, 09:57 AM
Rogeyboy
Rogeyboy's Avatar
Cheers i can't find it on their website, be worth a fonecall tho!
Old 15-01-2011, 09:41 PM
Puss2
Puss2's Avatar
Yeah just give Paul a ring very helpfull bloke
Old 15-01-2011, 11:11 PM
essexRSTSouthend
essexRSTSouthend's Avatar
Thats interesting to know.I think ill use the expanding clips now lol
Old 17-01-2011, 06:52 AM
Rogeyboy
Rogeyboy's Avatar
Cheers Puss! One from Roose £21 - Can't got wrong for that and Yes i'll fit it with expanding clips to makes double sure!
Old 17-01-2011, 12:46 PM
darrenb16two
darrenb16two's Avatar
Just ordered one from roose for mine this morning aswell
Old 17-01-2011, 08:39 PM
Puss2
Puss2's Avatar
No problem
Old 21-01-2011, 11:37 AM
Rogeyboy
Rogeyboy's Avatar
My Roose return elbow arrived yesterday... Nicely made peice of hose, needs cutting to fit tho!?
Also its nearly 30mm outside diameter, so will fitting with jubilee clips suffice?
Pics...
Im half tempted to return it and run a Ford elbow... straight fit that way, no messing about!
Opinions?
Old 21-01-2011, 12:19 PM
Danster76
Danster76's Avatar
Pics...
Opinions?
I had exactly this problem.
The hose I got from roose was WAY too big and would be no good aat all with spring type clips. I used heavy duty julbilee clips (again from roose). I had to clamp them up so tight to get it to seal on the return pipe that the outer silicone was damaged. On my new build I will be going back to the ford item.
HTH
Old 21-01-2011, 08:29 PM
Puss2
Puss2's Avatar
Copy the old one for length and normal jubilee clips job done
Old 21-01-2011, 09:21 PM
Danster76
Danster76's Avatar
I didn't mean too big in length, the internal diameter of the pipe was too big, maybe 3mm, so on the metal return pipe it's fit was as snug as a jonny on a spent cock!
Old 21-01-2011, 09:49 PM
Puss2
Puss2's Avatar
Ah i see mine was fine and never leaked
Old 21-01-2011, 10:03 PM
Danster76
Danster76's Avatar
Maybe they sent me the wrong one!
Old 22-01-2011, 08:54 AM
Rogeyboy
Rogeyboy's Avatar
Puss - Did your oil return look like the 1 they sent me?
How did you secure it?
Old 22-01-2011, 02:12 PM
Danster76
Danster76's Avatar
Here is mine
Old 22-01-2011, 08:55 PM
Puss2
Puss2's Avatar
Yes mate looks exactly the same and used jubilee clips to hold it on
Old 22-01-2011, 09:14 PM
Rogeyboy
Rogeyboy's Avatar
Did u trim it to size or did it go straight on, mines bigger than that i think!
Old 22-01-2011, 11:08 PM
Danster76
Danster76's Avatar
I had to cut mine down to get it to fit. But like I said, it was then a 'baggy' fit ID wise and not ideal for me jubilee clamped up.
Old 03-04-2011, 07:34 PM
kermitt
kermitt's Avatar
What is the I/D and O/D of the Roose pipe and is it the 45 deg elbow?
Old 04-04-2011, 11:40 AM
Rogeyboy
Rogeyboy's Avatar
Its 18mm id iirc and about 23-25mm od 90degree elbow, ring rouse and they have it on shelf ready to go in a range of colours!
Mines been on now for around 1,000miles as is fine! Altho the outer silicone layer is showing signs of melting lol!
Cosnada
07-01-2016 05:30 PM
DAZZER
30-09-2015 08:43 PM
Quick Reply: Oil Return, Elbow pipe.
