ZVH Power Output?
Old 04-01-2011, 10:24 PM
Jeffers_RST
Jeffers_RST's Avatar
Default ZVH Power Output?
im currently building a 2.1 for my van just wanted some opinions of what sort of power i could expect from this engine when its done from people who know a bit more about them,
- 2.1 silvertop block
- standard zetec crank
- acl heavyduty main and big end bearings
- forged h section rods arp bolts
- wossner low comp forged pistons 86mm
- efi head
- port polish, larger valves
- double valve springs
- poss. kent cam
- gt28 turbo
- dark greens
- grs intercooler
- ally rad
- gotech mfi pro management
- cometic gaskets
- uprated fuel pump
- alcon 6 paddle clutch
not sure on gearbox yet.
could i expect to see 300bhp?
cheers! neil
Old 05-01-2011, 08:31 AM
conor.rst
conor.rst's Avatar
not sure that greens would hit 300 ?
Old 05-01-2011, 08:57 AM
sas
should be good!
sas's Avatar
Well speeking from experiance you will max the greens out, better fit somthing like 440cc or larger.
Dont need big valve head. But you will need a better cam. I use a Newman with great results with the GT28 and 23psi of boost = 300bhp
Need some extensive flowing of the head.
Simon.
Old 05-01-2011, 07:56 PM
Jeffers_RST
Simon.
cheers mate any ideas what injectors specifically you would use? i havent bought injectors yet so im open to anything. i will look into a cam im not actually 100% what cam ive got but i believe it to be a kent one. i think i may have a newman one on an mfi head ive got.
cheers! Neil
Old 05-01-2011, 07:58 PM
Jeffers_RST
i dont really know what greens would hold up to mate if im honest.
cheers, neil
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
phil51
Ford Focus Diesel
02-10-2015 01:00 PM
Iain Mac
30-09-2015 09:39 PM
dojj
29-09-2015 10:32 PM
deathrider666
28-09-2015 06:12 PM
Quick Reply: ZVH Power Output?
