wat head gasket for 1900
Old 12-12-2010, 09:36 PM
martinmilne
martinmilne's Avatar
Default wat head gasket for 1900
wat head gasket is best for 1900 tall block and head bolts are other parts the same as a 1600 block ?
Old 13-12-2010, 04:07 PM
Canada1
Canada1's Avatar
same as 1600 block - if you are using the cvh head.
The bore size on the standard Ford gasket is 83mm. The bore on a 1900 is 82mm.
The standard head gasket will work fine, as will the standard head bolts - use new head bolts! These are stretch type bolts, and are not re useable.
Old 14-12-2010, 10:13 PM
martinmilne
wat are the diffrences between the 1600 and 1900?
Old 17-12-2010, 03:02 PM
Canada1
Canada1's Avatar
The 1600 is 80mm bore (std) X 79.5mm stroke
The 1900 is 82mm bore (std) X 88.0mm stroke
The 1900 block is 4.22mm taller.
bobsworth
77
24-03-2016 09:30 PM
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
DAZZER
30-09-2015 08:43 PM
Quick Reply: wat head gasket for 1900
