Boost Control
Old Sep 16, 2010 | 02:22 PM
drsrst2zvh's Avatar
drsrst2zvh
Default Boost Control
Is putting pre-load on the actuator a good way to control boost levels. Ie having no bleed valve just a pipe from actuator to turbo?
Old Sep 16, 2010 | 02:50 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Not an elegant way but if it works... Might wear out the actuator rather quickly...
Most professional way would be to get an uprated actuator with stronger spring.
Also it largely depends on what boost you want to run. If you only want 10 PSI it might be doable with a standard actuator, 14 - 15 PSI is definitely uprated actuator and/or bleed valve time.
Old Sep 16, 2010 | 05:02 PM
orionmojo's Avatar
orionmojo
I run 14psi with a bleed valve and have a -31 actuator, it works well.
Bleed valves are fine if dont look at them as a quick way to alter the boost. Set the car up with one on, and then just leave it alone. dont touch it... ever!
Old Sep 16, 2010 | 05:22 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Nothing wrong with just using a -31 and Amal, or as above with a bleed valve.
Old Sep 16, 2010 | 05:32 PM
drsrst2zvh's Avatar
drsrst2zvh
The car was currently just set up with a -31 and about 7mm of preload or 2/3s of the hole in the rod. It was only holding around a bar. I put a bleed valve on today and turned it out 1.5 turns and the car now holds around 16psi. Its going for a set-up soon to check fueling so we will see how it performs then.
Old Sep 16, 2010 | 05:57 PM
martysmartie's Avatar
martysmartie
There is nothing wrong with the standard amal valve so why change it?
With an electronic boost controller the ECU has control over the boost where as with a bleed valve it dosen't.
Martin
Old Sep 16, 2010 | 06:12 PM
rsmark86's Avatar
rsmark86
ive bloody brought one of them turbosmart boost tee things which are the best thing before a boost controller but because im gunna run such high boost its no good now and now i need a boost controller anyway lol
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
