brake help!
Old 20-08-2010, 08:23 PM
marv
marv's Avatar
Default brake help!
The brake pedal on my mk4 escort is soft when the engine is running, when the engine is off its solid. When its running and i pump the brakes my afr gauge shows it starts to run really lean the more i pump it. Anyone any ideas of what i could check? Must be drawing in air somewhere?
cheers
Old 21-08-2010, 09:04 AM
eoeumc
It's ALIVE..Well sort of!
eoeumc's Avatar
Well I have been having similar probs with my RS Cab and its got to be sorted so I can get mot done on it and drive it again
I had to change the rear shoes and slave cylinders, bled the brakes and all was fine. I now have got to change the master cylinder (being done today hopefully). Apparently the seals can go in the master cylinders which gives you the spongy pedal.
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: brake help!
