what do you think? compression test done today
Old 31-03-2010, 05:45 PM
diesel
diesel's Avatar
Default what do you think? compression test done today
iv just got back in from doing a comperssion test
and the results are
no1 cylinder is 142
no2 is 140
no3 is 155
no4 is 156
is this ok or are thay 2 far apart? and are thay 2 low?
any advice would be great
thanks diesel
Old 31-03-2010, 07:36 PM
mark2
mark2's Avatar
and the results are
no1 cylinder is 142
no2 is 140
no3 is 155
no4 is 156
thanks diesel
hi ya
was the test done wet or dry ,cold engine or warm ,all plugs out with fully open throttle
anymore than 10psi differance is not good may be rings or bores ,if test was done warm and wet looks like engine out time
mark
Old 31-03-2010, 09:18 PM
diesel
diesel's Avatar
Originally Posted by mark2
hi ya
mark
yes i done it with the trottle wide open all plugs out, i didnt realy warm it up, well i had it ticking over for about 5 mins then relised i left the compression tester up my house so i knocked it off. it took my about 15 20mins to return before putting the tester on it, should i have warmed it up to normal temp first?
i was told the other day in a thread but my computer keeps fucking up all the time so can get to them
Old 31-03-2010, 09:23 PM
.Ross.
.Ross.'s Avatar
How many times did you repeat the test?
And did you do a leak-down test or just a pressure test?
Old 31-03-2010, 09:24 PM
woolford
woolford's Avatar
Old 31-03-2010, 09:27 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Yeah engine must be up to temp mate.
Old 31-03-2010, 09:30 PM
diesel
diesel's Avatar
just the once on all of them apart from no2 witch i done twice just incase i had a leek
Old 31-03-2010, 09:35 PM
diesel
diesel's Avatar
i will have to do one again tomorrow. hopfully thay level out abit but knowing my luck thay wont lol
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
Fezman1
02-10-2015 01:22 PM
DAZZER
30-09-2015 08:43 PM
rsguy
44
29-09-2015 03:29 PM
Quick Reply: what do you think? compression test done today
